Message 1 of 3
Web site not accessible on broadband
The site eurekalert.org is not accessible via my BT hub but I can get it using BT mobile data.  Other people not on BT broadband are able to get it.  This has just started happening, I have used this site for at least a year.
I suspect it is a DNS problem, or maybe blacklisting.   I tried looking up their IP addresses and got  52.8.62.150 and 54.151.119.244.  Those don't work via my BT hub either - but on the mobile network they go to the main site for the organisation that runs eurekalert.org which is aaas.org.
Tony
2 REPLIES 2
Message 2 of 3
Re: Web site not accessible on broadband
Hi @TonyWoolf thanks for posting, do you have BT Web protect enabled on your connection? If so can you turn it off to see if that helps?
Neil
Message 3 of 3
Thanks! it's working again today so maybe slow DNS propagation. I didn't change anything.
