Message 1 of 3
What protocols are supported by SH2 as NAS?
I have an external hard drive connected via USB to the SH2 acting as a NAS. This works well for backup, for file sharing between devices on our network and, until recently, as a music library for a Sonos Move.
I'd like to know what communications protocols are supported by the SH2 for communication with the connected drive, whether I have any influence over what is being used and, if so, how I can alter the configuration. There doesn't seem to be anything configurable via the SH2.
The underlying issue seems to be that Sonos have removed support for SMB1 and I rather suspect that the SH2 supports SMB1 only. In which case I am 'stuffed' but I'd like to know for sure whether that is the case, and whether there is any 'get out of jail' card available to me ...
Philip
2 REPLIES 2
Message 2 of 3
Re: What protocols are supported by SH2 as NAS?
The SH2 only supports SMB1.
There are no configuration options available.
Message 3 of 3
Thank you ... <expletive deleted>!
Philip
