Message 1 of 3
Which wire goes where?
Evening all, my cable has just 2 wires - orange and white
Which wire goes into each numbered point? 5 3 2? Its a master socket 5c mk4 model.
My smart 2 hub just keeps flashing purple
2 REPLIES 2
Message 2 of 3
Re: Which wire goes where?
5&2 it doesn't matter which colour goes to which
Message 3 of 3
Hello @Louaa
instead of attempting to explain how to set it up and complicating things please check out this very helpful step by step guide with videos by simply clicking HERE.
Hope this helps! 🙂 If you like my reply and
want to say thanks for the helpful answer
then please click on the Kudos on left hand
side 😉 also if I answers your question correctly please let us know by clicking on Mark as Accepted Solution 😄
