Message 1 of 2
Which wires?
  • Hello, My partner has removed a small BT white telephone socket box  and we are trying to identify the wires it had connected to it... the two wires are identical- the wire casing is black, there are 3 coloured copper wires inside- orange, white and yellow. One wire looks connected to the wire leading to the telephone pole, the other wire enters the ?master box to which the wifi router is plugged into.
Many thanks
1 REPLY 1
Message 2 of 2
Re: Which wires?
The yellow is not a wire as such, it’s a suspension strand. Connect the orange and white
