Message 1 of 4
Wi-Fi 6 plug and play router
Cannot find a definitive list of plug and play routers for BT that use Wi-Fi 6. Our house suffers from really bad Wi-Fi and it’s not that big just thick walls.
Would love to avoid any bridge mode or dual routers and just have the one third party router. Budget is £400 max.
Broadband is BT 500mb fttp.
thanks
Tom
3 REPLIES 3
Message 2 of 4
Re: Wi-Fi 6 plug and play router
There is no 'definitive list'. Any router with a WAN port will work.
Bear in mind if you have Digital Voice it won't work with a third party router.
Message 3 of 4
Great, so it’s not like sky with option 61 requirement? Same line so wasn’t sure if it was the same protocol.
Cheers
Message 4 of 4
As long as it supports PPPoE, as virtually all will, you will be fine.
Login is the generic [email protected] with password BT.
