Message 1 of 5
WiFi Range
Hi All.
I have Bt Broadband but can't get a Signal in my Garage.
My Garage is in my Garden which is about 80-100 Feet from the Hub.
I have Tried the Plug in Range Extenders but they still didn't give a Strong enough Signal as it kept dropping out.
Tried moving the Hub Closer to the Garage but to no avail.
I want to put a WiFi CCTV Camera up on my Garage but need a Good Signal.
ANY IDEAS ???
Thanks in Advance.
Brian
4 REPLIES 4
Message 2 of 5
Re: WiFi Range
If your garage has a mains socket fed from the same consumer unit as the hub, use a powerline WiFi hotspot. Have a look at the TP Link range
https://www.tp-link.com/uk/home-networking/powerline/
Message 3 of 5
Re: WiFi Range
For a security camera I would run a cable in a conduit to you garage and connect to a wired power over Ethernet camera using a Poe switch.
Message 4 of 5
Re: WiFi Range
If neither of the above are feasible then one option may be to use a Yagi antenna - try a google search for "diy yagi wifi antenna" to get some ideas of what its about. You can, I believe now buy ready made antennas from the likes of  Aliexpress.
Given the option however, I would go with a wired solution if possible, either an ethernet cable or secondly the powerline option.
Message 5 of 5
Re: WiFi Range
Thanks for the Heads Up and taking time to Reply.
I took your advise and Purchased the AV1000 Gigabit Powerline ac Wi-Fi Kit and it Works a Treat, Getting 104mbps on my Phone.
Happy Days, Now to set up my WiFi Camera.
All The Best.
Brian
