Message 1 of 2
WiFi in summerhouse advice
Hi all, we’ve just built a summerhouse about 30m from the house. I’ve run some cat6 Ethernet cable to it and need to get WiFi up and running in it. We’ve currently got a Bt smart hub2 in the main house. What do I need to do now in terms of hardware and then set up? I’ve just got another BT smart hub 2 that I can put in the summerhouse but need some advice on setting it all up. Do I just connect them both up using the Ethernet cable with RJ45 connectors?
1 REPLY 1
Message 2 of 2
Re: WiFi in summerhouse advice
