Message 1 of 9
WiFi with TV problems
Since receiving a new router, my TV has to be reconnected to it every time it’s switched on. I have entered the WiFi password on the TV settings many times, and I now connect via WPS every time I switch the TV on.
Can anyone provide an answer please?
I have removed the previous router’s settings from the TV, entered IP manually, checked for TV (Samsung) updates and have no idea what to try next.
TYIA.
8 REPLIES 8
Message 2 of 9
Re: WiFi with TV problems
Hi @Jar34
I'm sorry to hear you're no further forward with this. If you call our team directly, they'll help run some checks to work out the best next steps.
Linzi
Message 3 of 9
Have you got a Samsung account?
Anonymous
Not applicable
Message 4 of 9
turn this off and try connecting again
and set the router to split 2. andd 5 ghz channels ghz channels  name them something diffrent
separate wifi channels
connect to using 2.4 with tv
Anonymous
Not applicable
Message 5 of 9
not having a samsung account will not stop your conneting only dowmloading apps
Message 6 of 9
Thank you. I will try that link on Monday.
Message 7 of 9
Hi Linzi.
Message 8 of 9
Thank you but this doesn’t work with a Smart Hub 3
Message 9 of 9
there is no SH3 for residential customers just the old SH2 and you cannot split the the 2.4/5ghz networks as suggested by @Anonymous
have you done a factory reset of the hub?  you could then disable the 5ghz network on the hub and see if the TV will connect to the 2.4ghz wifi.  once connected try turning TV off and then back on and see if it now connects automatically to the SH2.  if it does then re-enable the 5ghz network in the Sh2
