Message 1 of 14
Wifi extender for BT Smart Hub 2
We have underfloor heating with an aluminium heat spreader under the floorboards, so the wifi signal between floors is very weak. Any suggestions for a low-cost, easy-to-set-up wifi extender for the Smart Hub 2? We're on Full Fibre 900. I have an XtraBoost extender from my old system but this doesn't connect to the Smart Hub using the WPS buttons.
I don't need the BT Disk ... just a low-cost unit for one room.
Thanks!
Tags (2)
13 REPLIES 13
Message 2 of 14
Re: Wifi extender for BT Smart Hub 2
Don't get a WiFi repeater, have a look at the TP Link range of power line WiFi hotspots.
https://www.tp-link.com/uk/home-networking/powerline/
Message 3 of 14
Thanks for the prompt reply, but I'd rather keep the cost down to that of a single extender rather than a powerline system.
Message 4 of 14
I doubt there is much in it in terms of cost and a single device is always a bodge, but please yourself
Message 5 of 14
Wifi extenders... rubbish signal in... rubbish signal out.
Message 6 of 14
+1
Message 7 of 14
Message 8 of 14
@thameshaven wrote:
If that is in relation to the post with +1 it means that the poster agrees with what was posted previously.
Message 9 of 14
As I suspected but in my ignorance wanted to check.
Message 10 of 14
