Message 11 of 15
Re: Wifi range extension
I’d get a price to run cable around your building if you don’t want to do the job yourself.
Message 12 of 15
If you read the OP's first post it would appear that the OP's apartment is within an old mansion. The guest room is not his. It is a room that can be rented to all the apartment owners in the mansion. He can not run Ethernet cable along the shared corridor so it seems unlikely that he will be allowed to run Ethernet cable along the outside of the building or any where else outside of his own apartment
Message 13 of 15
I did but couldn’t see a reference to the property ownership. I am sure the OP can interpret and adopt suggestions to their own circumstances.
Message 14 of 15
Hi:
You are of course correct.
In fact all is well now, touch wood - I've obtained a two-node Tenda AC1200 Whole Home Mesh Wifi System, and this has greatly improved the Guest Room wifi.
Many thanks for all your excellent assistance - you definitely deserve your "Distinguished Sage" status! :- )
Cheers
Brian Randell
Message 15 of 15
Many thanks
