Anonymous
Not applicable
Message 11 of 12
Re: Wires in BT supplied ethernet cable
It might be cheaper overall to get someone in to run another cable & terminate it. The chances of successfully crimping on another RJ45 connector to a pre-made lead are slim, even if you have the correct crimp tool.
Message 12 of 12
Do-able if the correct plugs are used.  Solid core and stranded plugs are different.
You are right, however, its fiddly at best.  Doing it with failing eye-sight?  Well, good luck with that.
