Message 1 of 9
Wiring of master socket
I'm aware there's a few posts around this topic but have tried the solutions and not working for me.
I need to re attach the master socket and wiring in my house. I haven't got any extensions that need connecting. I need to know what colours go where please.
I have an AB terminal and 2 3 5 ports on the socket.
I have 3 pairs of wires
Orange with white/white with orange
Green with white /white with green
Blue with white / white with blue.
I don't have a telephone which needs plugging in, just a broadband modem
Pics attached for reference. If anyone can help I'd  be so grateful!
Please could you advise which needs to go into A&B and if any into 2 3 5
Thank you!
8 REPLIES 8
Message 2 of 9
Re: Wiring of master socket
Only 2 wires will be live, most likely the blue pair. Connect to the 2 terminals on the backplate of the socket, it doesn't matter which way round they go.
Message 3 of 9
Into A And B or The numbered ports?
Message 4 of 9
Are there any terminals on the backplate of the socket rather than the removable portion?
Message 5 of 9
Nope that's all, the A & B and 2 3 5
Message 6 of 9
In that case, A&B, the numbered terminals are for extension wiring.
Message 7 of 9
Thank you, I've done that, I'm still getting a red light on my router for broadband
Message 8 of 9
That is internal cable, you need to see where your external cable comes in and what colour wires are connected to it.
Message 9 of 9
I hadn't plugged the modem back in 🤦🏽‍♀️🤦🏽‍♀️ its all working perfectly now, thank you so much for your help and swift replies 🤗
