Message 11 of 15
Re: Gaming Lagging!!
I can practically guarantee the TV streaming is the cause of your issues.
Message 12 of 15
So would I need to get a better router with Qos or upgrade the internet package
Message 13 of 15
If the TV streaming is in 4K then it will almost certainly affect your gaming, but if that streaming is just 1080p then your gaming using a connection via a WiFi extender will probably be causing more problems.  WiFi extenders are great for many things, but gaming isn't one of those things.  If you have to connect over WiFi, see if connecting to the router directly is any better, and ideally, if you can get hold of a gigabit capable ethernet cable - the purists may not like the idea, you can get flat ethernet cables that are easier to hide!
*I certainly wouldn't suggest spending any money until you've tried the no-cost and low-cost options!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 14 of 15
Thanks for the information, i will give this a go tonight.
i noticed a red bar on the ping plotter tonight.
Message 15 of 15
Any idea what the red bar is
