Message 1 of 7
best router to switch smart hub 2.
what would be a better  choice? we have full fibre 100, with bt halo 3 +.
6 REPLIES 6
Message 2 of 7
Re: best router to switch smart hub 2.
Hi @newborn   If you don’t use the SH2 then you lose the two major benefits of Halo 3+. The Hybrid Connect and Complete WiFi both require the SH2.
Message 3 of 7
What are your requirements?
What is your reason to replace the BT hub?
What is your budget?
You might as well ask ' what car should I buy'
Message 4 of 7
...And if you're on digital voice, (or will be sometime soon), it only works through the SH2.
Message 5 of 7
so we used to be on digital voice but we don't have a landline anymore. so it's not being used, what if I got a second router to act like an accesspoint, would this work?
Message 6 of 7
Yeah but digital voice is delivered via the Smart Hub, anyway if you are not interested in a phone line either way then dont worry about that but as has been said, you have Halo3+, getting your own router not support those hybrid features you are paying for.
I think its probably best to mention what/why you are trying achieve?
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 7 of 7
As Naylor has said, digital voice is delivered via copper or fibre but, either way, it only works through the SH2.
