Message 1 of 2
broadband during power outages
If I power my broadband router with a battery ups, will the broadband still work in a power cut. Does the bt end have a generator back up?
Tags (2)
1 REPLY 1
Message 2 of 2
Re: broadband during power outages
It will still work. You need to power the BT hub and if you have FTTP the ONT will need powered as well.
