Message 1 of 3
bt smart hub 2
hi , I want to use the hub 2 as a modem but don't have the option for routing- bridge mode on the hub manager page -broadband.
Am I doomed or is there a way to enable it?
2 REPLIES 2
Message 2 of 3
Re: bt smart hub 2
There is no Modem Only setting on the Smarthub2.
Message 3 of 3
Re: bt smart hub 2
You can use the Smart Hub 2 for the Digital Voice phone and then your own router for the rest of your network, just not as a "modem".  Take a look at message 16 in this:
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Smart-Hub-2-and-Bridge-Mode/td-p/2306834/page/2
