Message 1 of 4
ethernet ports on halo 3 hub
Hi, i've just upgraded to Halo 3.  Unfortunately the new hub has only three usable ethernet ports, i need four.  Not sure what device i should get to rectify this.  as they all need to be operational at the same time.  Any help appreciated
3 REPLIES 3
Message 2 of 4
Re: ethernet ports on halo 3 hub
Any unmanaged Ethernet switch will do. Just connect one port to a LAN port on your hub and you will have n-1 ports left to use. An example of a 5 port switch https://www.tp-link.com/uk/business-networking/unmanaged-switch/tl-sg105/  about £16 from Amazon
Message 3 of 4
@sheradam
The 4th port on the SmartHub 2 is switchable between ethernet & WAN - which is the default.
If you've not got FTTP then in the settings - not sure exactly where - you can switch it back to ethernet so would save an extra bit of kit.
Otherwise the switch that @licquorice has suggested would be the perfect choice.
Message 4 of 4
@sheradam  As @TimCurtis  says, if you are not using port4 as a WAN port, you can change it to a LAN port in Advanced Settings > Broadband > Internet > Full Fibre (FTTP) Mode > Off
