Message 1 of 4
fibre 1: home hub solid blue light yet can’t find wifi
Hi,  my BT fibre 1 broadband had been working well till tonight (around 7pm-ish) - all of sudden none of my device can find my wifi.
tried restart my hub (5 times at least), factory reset, no luck - lights turned solid blue every time yet still can’t find my wifi in any device’s wifi list.
anyone had the same issue before? thanks.
3 REPLIES 3
Message 2 of 4
Re: fibre 1: home hub solid blue light yet can’t find wifi
If you have done that many resets including a factory reset and still no WiFi networks then it would problem with hub and phone CS 150 and request replacement.  I would not do anymore resets as that will have adverse affect on your connection speed if not already.
Can you connect using ethernet?
Message 3 of 4
thanks. that’s really helpful tips. No i haven’t tried ethernet since none of my devices has a suitable connecting socket for the cable i have. i’ve scheduled a BT engineer coming by tomorrow though.
Message 4 of 4
actually i just found one that connects. yeah ethernet works fine. so it’s only wifi.
