Message 1 of 7
iPhone11 connecting to wifi - but "no service"
Morning all,
Against my better judgement, my son got an iPhone. I know nothing about iPhones - rest of us are all android.
I had told him that if he got another detention at school, I would disconnect him from the house wifi using the MYBT app and remove his EE mobile data for a day.
He did. I did.
A day later, and I've given him his data back and reinstated wifi access and his phone will connect to wifi and see mobile signal but he keeps getting "No Service".
I have done a factory reset of our smart hub, he has reset his phone's network settings
Logging in to my hub I can see his phone. he is connected to the hub but no service still.
All suggestions gratefully received.
Tom
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: iPhone11 connecting to wifi - but "no service"
No service relates to the mobile network, not WiFi.
https://support.apple.com/en-gb/120000
Message 3 of 7
Sounds like Karma to me 😃
Message 4 of 7
Thank you. But he can't connect to the internet using our wifi despite being able to connect to the hub.
I'll have a look at the link.
Message 5 of 7
Has airplane mode been activated in error. Try toggling it off and on then restart the phone.
Message 6 of 7
THank you i'll check
Message 7 of 7
All sorted now.
Thank you all for your responses.
He simply needed to reset his network settings on his iPhone. 6 hours later, it started working!
Tom
