Message 1 of 1
iplayer not working at peak times
I am using a Home Hub Smart2 with an ethernet cable to a Samsung tv.
iplayer was working fine but now only opens off-peak.
It allows me to select a programme then defaults to broaadcast tv.
Later,say after 11pm,it works fine.
ITVX does not seem to have same rpoblems.
I have reset and reinstalled on the tv.
Is factory reset on the home hub likely to be beneficial?
