Message 1 of 5
weak security message on TP link power line
HI , I have used a TP Link AV500 extender cabled directly  into my BT smart  hub 2 with no problems . The TP circuit is s set up with its own password. However on my iphone when move away from the hub and I switch to the TP link connection I get a 'weak security' warning . I am not techi  and worried about screwing it all up but after some digging I was wondering would pairing it via the WPS button on the Hub  improve security ? or does the fact that  the link plug is hard wired into the Hub provide the best security anyway?  I assume that because I don't get the weak security message when connected to the hub it  means that is secure enough . Any advice much appreciated
4 REPLIES 4
Message 2 of 5
Re: weak security message on TP link power line
Ignore the paranoid iPhone warning.
Message 3 of 5
Thanks for the speedy reply , OK , Is there any advantage in cloning via the WPS button ? e.g will I only see the hub option throughout the house ?
Message 4 of 5
None whatsoever.
Message 5 of 5
Thanks again
