Message 1 of 5
Eero without password
Hello helpful people
I’ve moved into a house which we’ve bought through probate which has an eero mesh built into the house (it’s a smart home) We bought it from an elderly couple and there missing info on how to hook up our BT system to the Eero. We’ve discovered that the heating system runs via the Eero so are trying to work out how to connect the eero to a network.
Any assistance greatly appreciated,
thank you!
4 REPLIES 4
Message 2 of 5
Re: Eero without password
Message 3 of 5
See https://support.eero.com/hc/en-us/articles/207621056-How-do-I-set-up-my-eero-if-I-want-to-keep-my-ex...
Note that You can't put a BT router into bridge mode so you will have to use the double NAT method described
Message 4 of 5
Thank you!
Message 5 of 5
Thanks so much - managed to get the eero linked and the heating rigged up so me and my baby were able to get warm!
