Message 1 of 13
zoom internet unstable
Hello All
Need help / advice
I consider myself to be a fairly expert user (many years experience in technology)  -  for last 2  months have signficant issues with zoom with poor performance and 'internet unstable'  messages.  I have full fibre broadband  - excellent speed (upload and downland) and having monitoring tools checking speed and observe no issues whilst zoom is struggling.  I have tried virtually everything  I know ( it is not the laptop and try zoom else where using different broadband and no issues) - There is no issue with bandwidth , I have 20+ devices running however all my monitoring tools ( trying a few) show me I can plenty of bandwidth - SO PLEASE HELP  (and thank you in advance)
12 REPLIES 12
Message 2 of 13
Re: zoom internet unstable
This is a customer help customer forum for customers of BT Retail. I suggest you try your own ISP ZOOM customer forum for assistance
Message 3 of 13
@imjolly
@NaheemFazil  Could be referring to Zoom https://zoom.us/
As they are also using the application without issues on other broadband connections.
It could be local networking issues, especially if using a wireless connection.
Message 4 of 13
Hello there and thank you
Have tried both wired and wireless connections - same issue - router is 1 metre from my laptop
And if there was some type of networking issue , I assume it would reflect in reported bandwidth issues on my laptop - which it does not - s
Message 5 of 13
@NaheemFazil
Please confirm that you are talking about the application called Zoom, and you are on BT Full Fibre connection? What speed is your BT fibre connection?
The Zoom application can consume quite a bit of bandwidth, and if you have other devices streaming video content at the same time, then performance will suffer.
A wired connection is essential, to avoid any conflict with wireless connected devices.
Message 6 of 13
Hello there
Yes , it is ZOOM application .
On Full fibre connection and check my speed on my laptop constantly  - even when zoom is struggling and download speeds are above 300 and uploads are at least 50mb  -  and yes - connection is wireless - (have tried both wireless and wired)  - have spoken to BT as well and they have sent engineer who has performed the general tests and cant see an issue. -
Message 7 of 13
@NaheemFazil
I would suspect an issue with the performance of the laptop, perhaps other applications running in the background using up the internal resources.
If its a Windows laptop, you can use the task manager to see what is running, and what memory and processor usage they are using.
If you have a desktop computer which is wired to the home hub using an Ethernet connection, then try Zoom on that.
Message 8 of 13
Hello there
Not laptop issue - have checked that many times  - CPU , memory  and networking are all good  (I am running some fairly advanced tools to check and confirm the laptop is all good and it is - very advanced and powerful laptop with huge RAM etc )  - and when I try the same laptop with a different internet provider I am not getting the same issue  -
Message 9 of 13
You could try a factory reset of the home hub.
Message 10 of 13
done all of that - really appreciate all the advice and please keep it coming  (thank you)
BT have visited me and even provided an new router - and openreach done thorough checking of their network
