Message 1 of 3
BT Sport HD
Hi. I appear to be paying BT an additional sum for Spirt in HD but I'm not convinced I get it?  I have a Samsung TV on which I have installed the BT Sport App. How do I know if I have HD because the quality is not as good as BBC HD
2 REPLIES 2
Message 2 of 3
Re: BT Sport HD
The app will show the greatest quality that it's capable of. There's no SD subscription to BT Sport in the app - everyone gets access to HD if the bandwidth is there.
You can use the Device Checker from the cog in the top right corner of the main menu in the app to confirm what your setup is capable of.
Message 3 of 3
Re: BT Sport HD
thanks
