Message 1 of 5
BT Sport Ultimate now on Sky Q?
Hi All,
I can see BT Sport Ultimate is now showing as a channel on Sky Q, could you confirm this is now available and if so, if there is now any difference between paying Sky for BT Sport, compared to paying for a BT Sport Monthly Pass and using a ROKU stick which I have been doing up until now? The only difference before was access to BT Sport Ultimate?
@DarrenDev hope you are well? can you shed any light?
Scott
4 REPLIES 4
Message 2 of 5
Re: BT Sport Ultimate now on Sky Q?
Yes - BT Sport Ultimate has launched on Sky (subject to using a compatible box/TV).
If you pay Sky for it, then you'll only be able to watch on Sky, as usual.
The BT Sport Ultimate channel on Sky is always HDR - if the source video is SDR then it's mapped to HDR. This can sometimes cause unexpected colours/brightness, but this should only be for content where BT isn't the host broadcaster.
I can't comment on the actual quality of the Ultimate stream on Sky, to say if it's any better or worse than you'd get on Roku.
Message 3 of 5
Is there any word on sky sports uhd coming to BT?
Anonymous
Not applicable
Message 4 of 5
Message 5 of 5
Great thanks for getting back to me!
