Anonymous
Not applicable
Message 1 of 6
BT Sport app Champions League final issues - VC526
Just checking in to see if it is only me struggling?
4K feed started fine but then died, HD blurry and keeps stopping. Reset everything and tried again, could only get HD then error coded with VC526.
I’m using Apple TV. All others fine including the YouTube feed. Can stream Dolby Vision from multiple apps without issue.
5 REPLIES 5
Anonymous
Not applicable
Message 2 of 6
Re: BT Sport app Champions League final issues - VC526
Ultimate is back again, must have been a weird 10 minutes.
Message 3 of 6
I couldn't get the website stream to work, just the dancing-dots doing their thing and that was as far as i got. Went to YouTube in the end for the first half.
I do find the Apple TV BT Sport app is very unstable for quality. Its the only app i have an issue with, everything else is solid. (Airplay usually gets me a more stable result but that isn't definite either, its so frustrating)
Anonymous
Not applicable
Message 4 of 6
It was just that first half, touch wood it has been OK so far in the second.
YouTube was OK once I turned the quality up. Hopefully the experience will be more consistent across devices once it turns into TNT and moves into Discovery+.
Anonymous
Not applicable
Message 5 of 6
Spoke too soon, loading screen, bouncy dots and blurry vision is back. Sigh, only 5 minutes to go… 🤣
Message 6 of 6
Went to YouTube again for the second half. Absolute shambles honestly.
Indeed, hopeful the usually reliable Discovery+ doesn't change to something wavering and shaky, its usually very consistent.
