Message 11 of 29
Re: BTTV BOX PRO NOT SYNCHING WITH BTTV APP ON ANDROID 13
Are there any other Youview boxes connected to your broadband, if so may be worth temporarily disconnecting  them whilst you attempt to pair ?
Message 12 of 29
Hi ihave tried all that now i have also used a ipad with ios and another android using android 12 all with the same  result how am I suppose to series link programes if I can't use the app
Message 13 of 29
@zulu17 it should handle that ok - it pops up a screen listing all the boxes to choose from. I have 6 boxes on my network and can see them all.
Message 14 of 29
Hi exactly the same for me we where using ipads and android 12 as well how are you supposed to series link stuff of you can't use the app at least with sky you press the record button again and it will series link it
  • Might have to think about sending this back and staying with sky
Message 15 of 29
@trekerdwarf you can series link on the box too - just press the record button and it'll prompt to record series if it's available for that programme.
You could try a factory reset of the box, just in case that helps though?
Message 16 of 29
Hi @DarrenDev
The software on the box is 4.0.238, I checked for updates this morning after the factory reset and it confirmed the software is 'up to date'.
Message 17 of 29
I don't have any other Youview boxes @zulu17 .
Message 18 of 29
I will when i get home from work I would love to do the Ethernet cable but the box is a long way from it
Message 19 of 29
You could temporarily plug your box in next to the hub - you don't need to connect a TV. Just plug it in and bring it out of standby. If you see the box in the app then continue the pairing process until it tells you to press ok on the box. Wait 5 seconds and press ok/select on the remote. That should be enough. Once paired, you can then put it back where it was - it uses the cloud for all future communication.
Message 20 of 29
Thanks for that i give that a try aswell
