Message 1 of 4
Big sport subscription questions
Hello, I'm considering subscribing to big sport but just wondering if watching on the box that comes with the Big Sport subscription counts as a device when watching BT sport. I presume it does but watching the BT sport channel through the sky box doesn't which is why I ask.
Also, does Big Sport allow me to still watch through my sky box or is that a separate subscription?
Thanks very much for any help!
3 REPLIES 3
Message 2 of 4
Re: Big sport subscription questions
If you are refering to the set-top-box for BTtv - then that is NOT one of the devices counted towards your maximum of two devices.
If you have a BT Sport subscription for a BTtv box for Big Sport - then you need to pay extra to get it on a Sky box.
Message 3 of 4
Thanks for your reply. I'm referring to the box being mentioned here under sport/big sport which I guess is the BTtv box you are talking about?
Message 4 of 4
Yes - the BTtv box you get is not counted as one of the two devices you can register.
