Message 1 of 5
Re: BTP-15000
Hi @JohnC2 I am having the same issue on my box with BT Sport. The error message tells me that I do not have BT TV, but advisors on the phone can see I have.
Help! Thanks
4 REPLIES 4
Message 2 of 5
Re: BTP-15000
Hi @Tristanmjh and welcome to our community.
Thanks for posting about your error code issue. Can you just confirm what you've tried at your side i.e. resetting the box / hub etc? Are you using adaptors etc?
Cheers
David
Message 3 of 5
Re: BTP-15000
Hi David,
I sat on the phone with someone from the faults team and ran through everything:
- resetting connection
- Factory reset
- Turning off at the wall
- Turning hub off
- Hub reset
I am not using any adaptors, freeview is working fine through the aerial. I am connected to the internet via WiFi (set up using wps on the hub).
I am getting BTP-15000 when trying to access my subscription channels (sport), and it says I am not a BT TV customer. When I try to access the BT player app, I get BTP-15990 which also says I need a BT TV account.
Cheers,
Tristan
Message 4 of 5
Re: BTP-15000
Hi, @Tristanmjh Thanks for confirming that, I'm sorry it sounds like there's a problem with the subscription on our systems. I'll send you a private message so you can get in touch with the moderation team and we'll be happy to help.
Neil
Message 5 of 5
Re: BTP-15000
Hi @Tristanmjh ,
Sorry for the delay in getting back. I can see our specialists managed to fix this for you. Let us know if you have any other problems.
Cheers
David
