Message 1 of 9
Can’t get sports channels on downstairs tv
I can get all channels through my bt box but not the sports channels that I subscribe to. However bt box upstairs works fine. I’ve rebooted hub and the bt box downstairs but still nothing. Any suggestions.
8 REPLIES 8
Message 2 of 9
Re: Can’t get sports channels on downstairs tv
Is this a new subscription or a problem that has just appeared? How is the downstairs box connected to the hub? WiFi, Ethernet or powerline adapters? Have you tried a software update on the downstairs box?
Anonymous
Not applicable
Message 3 of 9
Silly question but do you have muti room?
Message 4 of 9
Had the subscription for nearly a year and it’s a wired system upstairs which doesn’t work but a WiFi system upstairs which does work.
Message 5 of 9
No,  that’s far too sophisticated for my household
Message 6 of 9
@Toptaurus
You need multi room subscription to get sports on more than tv
Message 7 of 9
Then I do have this, didn’t know it was called this.
Message 8 of 9
Yes, if you’ve got 2 boxes and neither of them are yours, you must have multi room. Have you tried a software update on the downstairs box?
Message 9 of 9
Thanks so much for your suggestions. Had to resort to asking my son to visit to fix the problem. Turns out the box wasn’t pairing. Within 10 minutes it was all sorted.
