Message 11 of 25
Re: Casting from the EETV app to my Chromecast dongle issue?
Thanks for the update.
Why would restarting the casting allow it decode the problem section successfully? Is that a clue to what the problem is?  Or am I misunderstanding what you mean by "section of the buffer"?
As it happens I cast two of the weekend's rugby games today and they both played through without a hiccup apart from one momentary buffering glitch. I did wonder if there had been any update to the dongle system app/software but could not see anything since last week when I was last having problems.
Message 12 of 25
The video is cut into 4 second chunks, and delivered at multiple different quality levels. Your device reported that it couldn't decode one of those chunks, however that chunk plays fine for us - so we don't know why it fails.  If you restart the stream at the same point, the player will be reset - there's a chance that it'll be able to play that same chunk this time, but there's also a chance that your device will attempt to use a different chunk.
I'm hoping the new logging will help me understand more about the pattern leading up to the failure.  If I can understand the pattern, I may be able to work around it.
Message 13 of 25
Cast another rugby game this morning with no problems so I am now wondering if the Chromecast rollback you reported last week didn't take effect (for me) until a day or so later as initially I still saw problems and left it until this week to try again with the latest round of rugby to play with.
Message 14 of 25
Saw there was an update to the Webview app this morning. Cast a rugby game and that was back up to its old tricks of stuttering and eventually hanging. So whatever changes they made to WebView have not been for the better.
Gone in to Force Stop and Clear Cache the Webview app and will see if that make a difference when I cast the last game of the weekend tomorrow morning.
Message 15 of 25
The Webview app on your phone isn't relevant to the Chromecast experience. The differences in behaviour you're seeing now aren't as a result of any changes to either Chromecast or the EE TV app - they'll most likely environmental (wifi or broadband related).
Message 16 of 25
Unlikely. Ethernet connection, not wifi and it played perfectly on the Youview box only minutes later.
Message 17 of 25
This morning's attempt at casting the rugby resulted in the stream crashing with loss of playback position needing casting to be re-established and play point manually restored before watching the end of the game (about ten minutes out of 47).
So still very much an outstanding issue.
Message 18 of 25
When you say crashing, what do you mean?  Was an error shown on screen?
Message 19 of 25
It was. CP something or other.
Message 20 of 25
Got a text this week saying TNT Sports catch up will no longer be available in the EETV app on my Youview box (it is an older 4000T model). I can get a new box apparently but the text fails to say if that is without charge. It is also not clear if that means TNT Sports catch up will no longer be available via the app on my phone or the web site on my tablet either. Anyone able to clarify this for me?
But it does seem that I will falling back on using the HBO Max app on my Chromecast dongle and live with the faff of skipping the ad breaks or if I remember recording broadcasts of highlights on my existing Youview box.  I see no point in getting a new box if it is only so I can get the HBO Max app on that.
