Message 1 of 4
Discovery plus keep freezing on 2019 LG smart tv
Discovery plus keep freezing on 2019 LG smart tv, downloaded the app on phone and tablet and they work fine but not on the TV, I have checked all the connections. No problems with other apps on the TV
3 REPLIES 3
Message 2 of 4
Re: Discovery plus keep freezing on 2019 LG smart tv
Hi yes same on my LG tv as well.
I cant watch nothing on discovery plus on that tv, yet all other apps work fine
Message 3 of 4
Thank you.  A shame  though to know that I am not the only one. On BT it says that your TV must be 2018 or later, which mine is.
Message 4 of 4
Hi, @stuartartist37 & @Jason001 I'm sorry to see you're having problems with the Discovery + app on your LG TV.  The Discovery help pages advise that it supports LG TVs with WebOS 4X/5X (2018 models and newer)
Please can you follow these steps on the Discovery support pages if these checks don't help there's a contact option on that page to raise a case with Discovery support.
Neil
