Message 1 of 3
Enhanced player
I don't use a TV - I use a desktop to watch BT Sport.
However, I would like to watch this using the enhanced option. Whenever I do this the whole player seems to crash within a couple of minutes, which then means I have to go back to standard definition, again. My internet isn't the problem as I'm on Halo 3+
Is there a fix for this and is anyone else experiencing this problem?
2 REPLIES 2
Message 2 of 3
Re: Enhanced player
The enhanced player doesn't offer enhanced quality - it's the same quality as the standard player.
If you only want to watch the match, without any of the additional features, then stick with standard player.
Message 3 of 3
Re: Enhanced player
That makes a lot of sense,
This whole time I've been here thinking it provides better resolution. It probably should be made more clearer that the enhanced player only has interactive elements. Just a food for thought
