Message 1 of 7
No audio on BT Sport ultimate on Virgin V6 box
I was watching BT Sport Ultimate via a Virgin V6 box when the audio suddenly cut out. I made no changes to audio setup and I have watched BT Sport Ultimate in the past with no problem. I have tried changing audio settings on the V6 box (which I have also reset) and the TV but to no avail. Audio is fine on all other channels including the BT Sport HD channels.
Any suggestions gratefully received.
6 REPLIES 6
Message 2 of 7
Re: No audio on BT Sport ultimate on Virgin V6 box
Are you watching via the BT Sport app or Virgins EPG?
Message 3 of 7
Virgin EPG
Message 4 of 7
Ahh ok. You'll need to contact Virgin Media then in the same way you would for broadcast issues on any other channels...
Message 5 of 7
There is (or was) a known sound fault on VirginMedia with Ultimate in the Nottingham and Derby area.
Message 6 of 7
Fair enough - just wondered if anyone had come across this problem and had a solution
Message 7 of 7
Thanks - Looks like it’s a new issue in our area and Virgin Media are working on it
