Message 11 of 14
Re: Package Renaming and HD Upgrades?
All well and good but the issue is, recontacting 6 months into a 24month deal is pretty daft. Id rather BT/EE offered the best quality and if offering HD as a standard is now part of the package im on, then applying that accordingly like other platforms do shouldn't be an issue, especially if there is no price change, which im told there isn't! Its just bad taste.
Message 12 of 14
Flexing tv does not recontract the package so tbh you'd have nothing to lose by checking options
Message 13 of 14
OK, just to settle this, I've looked at your current subscription @Popeye13_Official - if you switched to the new package, your price would increase by £2 a month*. Alternatively, you can choose to add the HD add-on for £6 a month.
As you're at the beginning of your contract, it makes MORE sense to change package and lock the new price in now, but it's entirely up to you.
Alternatively, you could wait until SD is switched off - I don't know when that will happen, or what will happen to existing subscribers.
* comparing current contract to published rates. I cannot confirm the exact price you'd be offered.
Message 14 of 14
I checked this - flexing to new packages would trigger a recontract.
