Message 1 of 2
Sony Bravia 32" / BT Sport app
Is it possible to use the BT Sport app on a 32" Sony Bravia? It uses Android TV, so I think it should be. However, I've come across a lot of conflicting information across the internet, such as it's only possible on the larger 4k models. Would like to hear from anyone currently using the app on a 32" model. Thank you
1 REPLY 1
Message 2 of 2
Re: Sony Bravia 32" / BT Sport app
The size of the TV is irrelevant - all Android TVs are supported.
If the TV doesn't support 4K then you'll not be able to watch BT Sport Ultimate, however all other content will work OK.
