Message 1 of 8
TNT Sports not showing on program guide.
I can view TNT sports on the discovery plus app but not on the program guide on my pro box? Do I need to do something else to get them to appear? I have Sky sports on Now tv and they show on the guide.
7 REPLIES 7
Message 2 of 8
Re: TNT Sports not showing on program guide.
I can't see any reason why you wouldn't see them in your TV Guide. So channels 408 - 411 are just missing completely? What if you press Yellow when on the TV Guide - could you maybe have hidden them?
Message 3 of 8
Observation.
There is this thread
https://community.bt.com/t5/TV-Content-including-TNT-Sports/Now-TV-channels-showing-on-EPG-but-not-a...
of potentially similar issue with this box.
Message 4 of 8
It should be an all or nothing thing - either all the subscription channels appear, or none of them do. I'm not aware of a config that would include the Sky Sports channels, but not the TNT Sports channels.
Anonymous
Not applicable
Message 5 of 8
What's the full story?
  • Did you have the channels previously on the Pro Box but they've disappeared?
  • Did you have the channels on another box but changed to the Pro & now not showing?
  • Are you perhaps inadvertently subscribed to the app only access?
Message 6 of 8
Sorry I wasn’t very clear. I can see TNT sports on the programme guide but when I click on it I get this message.
You need to set up TNT sports 1 or add it to your tv package.
Press ok for more info.
When I press ok nothing happens?
Message 7 of 8
I didn’t have discovery + on my old box and only added it to the pro box.
Message 8 of 8
Could you please try launching the BT Player from the apps menu. Does that launch ok? It's a good test of whether the box and account are set up correctly.
