Message 1 of 4
TNT sports stuttering
Hi,
I'm watching TNT sports 2 (NOT HD) on my TV using my BT box. My internet connection is fine (I can watch a 4k video on YouTube with no issues) but it's frequently doing this: https://youtu.be/iB6slBeUAQE?si=T87yyaopJVkTXO_2
I've uploaded a video so that you can see for yourself, any ideas?
Thanks,
Matt
3 REPLIES 3
Message 2 of 4
Re: TNT sports stuttering
How is your TV Box connected to your BT router?
Message 3 of 4
With an ethernet cable
Message 4 of 4
Thanks for posting the video. That's classic pixelation and macro blocking caused by packet loss on the multicast channel, and the artifacts are where the box isn't able to "fill in the blanks" - a bit like missing pages in a book, where you can just about work out where the story is going but not how it got there.
If the box is Wi-Fi connected, it could be suffering poor reception but as you mention a 4K stream is playing it suggests the problem might be specific to the multicast throughput via from the network via the hub.
If you'd like me to check please ping me your TV box serial number in a DM and I'll take a look.
Cheers
David
