Message 1 of 7
can't watch nowtv sport in two rooms even with everywhere box???
Hi
I can't watch nowtv sport in two rooms even with everywhere box any reason? Please help x
6 REPLIES 6
Message 2 of 7
Re: can't watch nowtv sport in two rooms even with everywhere box???
Have you got Boost? If not you can only watch on one screen at a time.
Message 3 of 7
with the now tv hd boost can watch now tv on think around 6 devices i.e i have it on pro box ,via smart tv app ,old bt 4k box  in bedroom and on firetablet all allow you to watch whatever now tv package you have with bt  , you can only have Bt sport loaded to one box at a time otherwise have pay extra for multiroom box which think is £10 p/m
Anonymous
Not applicable
Message 4 of 7
To clarify, although you can have six devices registered at a time, you can only watch on three simultaneously with Boost.
Message 5 of 7
Thank you
i have 2 boxes but can only wtch sport on the one that is attached to the main hub.
If you get a firestick can that be used in the other room i am not very techy
Message 6 of 7
Thank you will check out boost x
Message 7 of 7
@Dollie
Assuming you have your Now membership in your BT TV package.
BT customers can watch on 2 devices at once (as long as one is a BT TV Box and you start streaming in the correct order), or 3 if you have NOW Boost. If you're watching on a BT TV Box, to watch on 2 devices at once you'll need to leave the NOW channels and start watching on the NOW app. You can then return and watch NOW on your BT TV Box as well. You can watch live on your BT TV Box, and live or On Demand via the NOW app.
