Message 1 of 6
cancelling tnt sport
trying to cancel my tnt sport subscription. bank statement says tnt sport. various places i've tried to go to find a place to cancel the subscription (hbo max who i have to stream it via, ee because i have other subscriptions with them and they seem to be connected to this whole thing somehow) points me towards the account being with bt/ee but i am just being sent round in circles and the bt help bot doesn't seem to be able to help with this matter. help!
5 REPLIES 5
Message 2 of 6
Re: cancelling tnt sport
which company do you actually pay for your TNT sports - BT or EE or someone else?
Message 3 of 6
It says tnt sport on my back statements. It was probably set up back when they were bt sport and automati
Message 4 of 6
If it was purchased in BT Sport days then check www.bt.com/mybt
Message 5 of 6
Thanks, that seems to be where I needed to go
Message 6 of 6
If you are currently accessing it via HBO Max -  in HBO Max app there is it its menu  (normally at the bottom on EE  TV Box) or if using the mobile app  tap your profile image (typically top right)
Settings  - if you select Settings  there a option to select  Subscription   which normally would describe your Current plan  - probably TNT Sports  and how you manage your subscription  - if it is via BT/EE it will say so.
Also under Settings there is Account  which if selected should confirm the email address  and name  that you are using.
