Message 1 of 3
is there any way to erase or rearrange featured apps on the BT Box?
I would like to prioritise the apps on my BT Box, ideally to delete the apps I do not ever use, and/or shuffle the apps so that those I use are in the prime location, does anyone know if that is possible? If so, how to do it?
many thanks
Tags (2)
2 REPLIES 2
Message 2 of 3
Re: is there any way to erase or rearrange featured apps on the BT Box?
Not possible
Message 3 of 3
ok thank you .. that really sucks though 😞
