Message 1 of 3
Big Sport
How can I simply remove BT Sport from Big Sport for 2 Months?
             At the moment there is nothing on BT Sport that interests me so I would like to remove it from my Big Sport Package and just have Sky Sports for a couple of months.I can see NO WAY to do this simply on line (which I thought was an easy option available to all).
                  To be clear,I just want to use Sky Sport only for a couple of months and then (with no hassle!) revert to Big Sport when the Football starts again.
                Any suggestions,please.
                       Thank you.
2 REPLIES 2
Message 2 of 3
Re: Big Sport
You'd need to downgrade to the Entertainment package (as you need to select one of the base packages), and then add the Now Sports add-on. I believe this would work out much more expensive than the package you're on though. You'd also lose access to Eurosport and Discovery+.
Message 3 of 3
Re: Big Sport
Thank you for your swift reply.Much appreciated.
