Message 31 of 63
Re: BT-TV BOX PRO
Can you still have it wired to the hub in IP MODE?
Message 32 of 63
Re: BT-TV BOX PRO
@sea2dog Yes you can still choose to use a wired ethernet connection or wifi.
Neil
Message 33 of 63
Re: BT-TV BOX PRO
@NeilO
I have a fast Internet speed so I would assume that not having a wired connection won't cause any issues, however, would you say that using a wired connection from box to hub would be preferable?
I have FTTP.
Message 34 of 63
Re: BT-TV BOX PRO
Hi, @sea2dog it really depends on your personal preference and the location of where you are situating the Pro box. Using wifi is often the easiest option and won't involve any trailing ethernet cables around your floor, if you have fast internet and a reliable wifi connection then there shouldn't be any problems.
Neil
Message 35 of 63
Re: BT-TV BOX PRO
@NeilO
The box will be sitting underneath on its own space and the hub sits on the same level as the TV.
Message 36 of 63
Re: BT-TV BOX PRO
@sea2dog in that case I'd use an ethernet cable.
Neil
Message 37 of 63
Re: BT-TV BOX PRO
@NeilO
May I ask why? as they will be only approx 30 inches from each other albeit on the level below on the same unit and still in the same room, sorry if I didn't explain it properly.
Message 38 of 63
Re: BT-TV BOX PRO
I see this online so it agrees with what you said, but I thought that if it doesn't work as good wirelessly for being that close then I don't see any better quality options other than this:
For the best internet connection, direct Ethernet to Router connection is recommended even if you have a Wi-Fi enabled box.
Message 39 of 63
Re: BT-TV BOX PRO
An ethernet cable is always preferable for a stable connection.
Message 40 of 63
Re: BT-TV BOX PRO
@sea2dog sorry about the delay getting back to you, I see you found the answer. Personally, I'd only use the wifi option if my router was too far away from the TV box to run an ethernet cable. As @Hunter2660  mentioned you're always going to get the most stable connection using ethernet.
Cheers
Neil
