Message 1 of 7
EE Mini Box UHD
Hi, Have to change to EE tv from BT tv and was wondering if you can view UHD on the EE mini box. Also, do you have to connect the mini box via WiFi or can you plug in  wired if you have the facility?
6 REPLIES 6
Message 2 of 7
Re: EE Mini Box UHD
Hi @yellowandgreen
Just to clear any misunderstanding there is no BT TV anymore , it is EE TV.  That is as a result of BT group deciding to focus on EE as being its principal consumer brand.
The EETV products and offers available with BT broadband  differ from those available with EE  broadband.   So if you opt to move from the BT broadband to EE broadband  you have a different set of offers for the EE TV service ( for example the option of Apple TV  box rather than a Box pro recordable device if you wish  , and  current offers of a free Box mini as a multiroom option ).
You should not at this stage be forced to move to EE broadband as BT broadband still available as a brand .
There are some reported issues with the EE TV box mini when on Ee broadband over Wi-Fi with EE smart hub  see post c 6th Sept in
https://community.ee.co.uk/t5/TV/TV-Box-Mini-Issues/td-p/1404635/page/2
You can use a wired connection  for the Box mini (there are guidelines as to recommend maximum distance from the hub).
The EE TV Box mini would have the same live TNT Sports ultimate channels available as the Box pro  and the on demand players should be at least as good  if not better as those on the Box pro. The Box mini does operate in IP mode  for its free to air channels ( ie no aerial option).
At the time of posting EE TV have not announced when and on what devices the recently launched Now Ultimate Boost will be available.
Message 3 of 7
Re: EE Mini Box UHD
That's really good information. Many thanks.
Message 4 of 7
Re: EE Mini Box UHD
@zulu17
As good as, sure, but why would the players on the Box Mini be any better than those on the Box Pro?
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 5 of 7
Re: EE Mini Box UHD
Message 6 of 7
Re: EE Mini Box UHD
@zulu17
Thanks. Somebody pulling a FAST one…
Message 7 of 7
Re: EE Mini Box UHD
The TV Box Pro is a year older than the TV Box Mini, but more importantly, the core system drivers on it are a year older -this is why it doesn't support the FAST channels. Updates at that low level require updates to everything on top (including every single app), which is a huge task.
Also, the Pro supports Wifi 5, the Mini supports Wifi 6.
