When I select HDMI 1 on LG TV source button, description shows ‘TalkTalk’. Never been with TalkTalk, with BT for years. Anyone have any idea what would cause this ?
Solved! Go to Solution.
Which version of BT TV box are you using, the new "Pro" version or an older Humax made one?
My LG TV has loads of fancy settings relating to unifying control of connected devices so you can use the LG TV remote on the box and TV, I suspect it has mistaken your BT box for a TalkTalk one (which suggests it is an older model to me).
It's easy to change, what is your model of TV?
On mine, a long press on the input button allows me to go in and make changes to each and every input. Here you can see my Sky Q box reporting correctly, if it wasn't I can change the name and control easily:
Hello @stereohaven thanks for reply. TV is LG OLED55CXLB (2020). Box is HUMAX DTRT4000
I had this happen with our new Pro box and LG TV. It was displaying talk talk in input 1. I got engineer out who thought I had typed in Talk Talk to appear on the LG input. I have never been with talk talk. When the TV came back and said nothing to change he swapped the BT box pro for one in his van. We went through the set up and input said BT TV west Midlands. I kept the new box and the old was taken away.
@Robh1wrote:Hello @stereohaven thanks for reply. TV is LG OLED55CXLB (2020). Box is HUMAX DTRT4000
Cool, nice TV, much newer than mine so apparently you should have been encouraged to download a ThinQ app?
If you have, you can change the name of any connected devices in there or press and hold the input button on the magic remote to get into your version of the screen I posted above:
The online user guide is here if needed.
Sorted, it annoyed me more than it should!
Go to Home Dashboard via Home. Top right of screen select Settings/Edit. This shows a list of devices. Select the one to change and edit to the new name. Thanks for suggestions.
