Message 1 of 2
Now tv via BT TV
Anyone any idea what streaming in the right order means? I have copied and pasted what I have got from online. I can’t work out what it means by start streaming in the correct order.
If you've got NOW Boost, you can stream on 3 devices at a time. Otherwise, it's just one. If you're a BT customer, you can watch on 2 devices at once as long as one is a BT TV Box and you start streaming in the correct order.
1 REPLY 1
Message 2 of 2
Re: Now tv via BT TV
Hi @msawyer570
BT customers can watch on 2 devices at once (as long as one is a BT TV Box and you start streaming in the correct order), or 3 if you have NOW Boost. If you're watching on a BT TV Box, to watch on 2 devices at once you'll need to leave the NOW channels and start watching on the NOW app. You can then return and watch NOW on your BT TV Box as well. You can watch live on your BT TV Box, and live or On Demand via the NOW app.
