Message 11 of 19
Re: Sky Mix replacing Pick
I know it a bit ridiculous to be honest.
I was living in hope but I am giving up...
Message 12 of 19
It is yes . Sky and virgin get the deals but bt never do and its never there fault.   Bt are basically not willing to pay the asking price thats what it boils down to.  They could have all the channels but choose not to.
Message 13 of 19
Spot on
Message 14 of 19
It would be helpful for BT to advise impact if any of the change . For example on schedule recordings and any series recordings set up on PICK. Will BT/Youview treat them as new channels or simply channel renames and will changes in LCNs be transparent.
Message 15 of 19
Judging by past experience what are the odds of that @zulu17
Message 16 of 19
It launched yesterday did it not?
Forgot to check on my planner.Im at work now
  Is it standard SD or HD?
Anyone confirm?
Anonymous
Not applicable
Message 17 of 19
SD @LondonCelt, we are all shocked. 🤣
Message 18 of 19
Yes SD, but HD on Freesat, so there's little reason not to replace Sky Mix in HD in IP mode. It's up to Sky and BT to sort I guess.
Message 19 of 19
Thank you .
