Message 1 of 6
Data only sim card
Can I use a data only sim card in my car
Landrover Evoque 2019 it syas it needs a sim card and the one supplied costs a bomb
Ideas ??
5 REPLIES 5
Message 2 of 6
Re: Data only sim card
I think you'd be better off asking this question on the Land/Range Rover forums. As firstly, you'll need to assetaine if the car will accept SIM cards from any networks and whether the car software allows you to use another SIM to access Land/Range Rover services or not. Once you have confirmation of this, you can then look for a data only SIM package. EE do a data only SIM package.
Message 3 of 6
I use a 3 data only sim in my 17 plate Evoque. Bought from eBay, 24Gb over 3 years. I did use my normal BT sim, which worked, but not a data only one.
it might be worth you looking at the Evoque Owners Forums. I know they have discussed this before
Message 4 of 6
How long does 24gb last for you ??
Message 5 of 6
Sorry. Didn’t see your reply. I’ve used 4gb in 18 months
Message 6 of 6
Thank you I have got a 12 gb 3 data sim in now and it works fine cheers for replying 🙂
