Message 1 of 8
How can I provide positive feedback?
Why is there no facility for this?
7 REPLIES 7
Message 2 of 8
Re: How can I provide positive feedback?
After ten plus miserable days on the phome to BT last night I stumbled upon a brilliant individual who simply said "I know what the problem is" and solved it in less than half an hour. Yesterday I was on the phone for over three hours and that has not been unusual and this guy just sorts it out for me. I cannot praise him enough but can only find facilities to complain.
Message 3 of 8
@tonychurly
Welcome to this user forum.
You did post feedback but unfortunately it contained personal information and this is a public forum.
I quarantined your post to protect your privacy, and also asked a moderator to edit your post to remove that private information.
Its quite likely they will post back here, and ask you to send the details privately.
Message 4 of 8
Thnx
Message 5 of 8
Good morning @tonychurly,
Thank you so much for reaching out to leave such a positive review about your experience. I am sorry that you weren't able to get the help that you needed before you got speaking with this adviser. I will be able to look into this for you and try track down the person that helped you. I'm sending you a private message with some details that I need.
DanielS
Message 6 of 8
Hi @tonychurly, thanks for getting in touch. I was able to locate the person who spoke with you and resolved the fault.
I've passed your message on to their manager so they can be recognised for the excellent service they provided.
Cheers
John
Message 7 of 8
I would also like to provide positive feedback to one of your advisors
Message 8 of 8
Hi @Rhiannonm Thanks for posting, I'll send you a private message and we can pass on your feedback to the advisor and their team leader.
Neil
