Message 1 of 12
Problem with using my Apple iMac - can anyone help?
Hello 😀
Can you tell me why this service is turned off on my personal BT router?
Thanks if you can!
David
11 REPLIES 11
Message 2 of 12
Re: Problem with using my Apple iMac - can anyone help?
I doubt it has anything to do with BT.
Presumably you have an up to date iCloud+ account ?
Message 3 of 12
Yes - everything is as up-to-date as one can get! 😎
It's named my BT router so it MUST have something to do with BT!!!
Message 4 of 12
Apple Private Relay is an iCloud service similar to a VPN. See here https://support.apple.com/en-gb/HT212614
Message 5 of 12
Private relay is part of iCloud Plus (iCloud+) which is a subscription service, do you have an iCloud Plus subscription? if not then it won't work
Message 6 of 12
@BoaterDave I've just re-created that problem and, at least for me, it's because "Limit ip address tracking" is turned off. Check your WiFi settings.
Message 7 of 12
Hi Dodi 😀
Thank you so very much for your help with this.
There's always a reason for everything - and you 'hit the nail on the head'!
Would I be right in thinking that you yourself have an Apple computer?
Please let me know. If you really are an "expert" I may have another question for you! 😉
David
Message 8 of 12
Many thanks for your response - especially the link!|
David
Message 9 of 12
"Would I be right in thinking that you yourself have an Apple computer?"
Yes.
"Please let me know. If you really are an "expert"
No.
Message 10 of 12
Yes, I do have an iCloud subscription in place.
As you'll no doubt note, that wasn't what was causing the 'error'.
Thanks for responding. 🙂
David
